Home › Forums › Products › Stompboxes › Mix level question on Timefactor › Reply To: Mix level question on Timefactor
July 5, 2008 at 5:34 pm
#117635
I just tried this out for you… There is no difference in the dry level from 0-50 on the mix.
The new taper gives you more control in the lower mix ranges, though personally, I would still like a bit finer control in the 0-5 range.
50/50 mix is now a little past 1:00 on the knob as opposed to 12:00.
