Home › Forums › Products › Stompboxes › Expression pedal range change since new firmware? › Reply To: Expression pedal range change since new firmware?
        July 11, 2008 at 11:37 am
        #117670
Actually, the TF and pedal are all mounted to a pedalboard. It's always plugged in.
Realistically, the biggest problem is not being able to adjust the pedal any more. I could live with the range being shifted…..but at this point, the expression pedal function is really broken since it's stuck where I left on each patch before the update.
