Home Forums Products Stompboxes expression pedal ..controlling TF & MF (at the same time?) Reply To: expression pedal ..controlling TF & MF (at the same time?)
#117720
     You can connect one (1/4" jack type) expression pedal to both TF and MF via a Y lead.
    Or you could use a MIDI pedal to control both units in series (set the first one to MIDI THRU).
    This would require them both to be set to the same MIDI channel, which would mean that all MIDI commands (not just the pedal) would be sent to them both. With careful choice of CC or ProgChange values this would be OK.
