Home › Forums › Products › Rackmount › Overload Issues and Levels › Reply To: Overload Issues and Levels
#117755
 MB
to correctly set the input level:
when using analog inputs, the LEDs show headroom saturation. Since the 8000 has about +26dB input headroom, the top led would indicate +26dB over 0! You should only need to light up the first 4 LEDs to get the best signal/noise ratio.
When using digital signals, the top LEDs indicate the 0dB.
There may be different reasons why you can find some difference in levels in the presets:
-sometimes it's their own fx structures that can be very reactive to input transients (diffusors – ring modulators – preamps – etc.). These fx can result in very different levels according to the input source.
-some presets may not have levels control because they may be too large to include these in the algorithm. Since the unit has system levels, when needed…an option exists.
-controlling system input levels via MIDI CCs is very effective in working situations.
best
I
