Reply To: Saving Play mode settings
Home Forums Products Stompboxes Saving Play mode settings Reply To: Saving Play mode settings
#117903
plinky
 Alright. I reinitialized the TF and double checked sw & serial #s and they're all ok. I went through and built my preset in play mode and saved it to bank 1:1 with no problems (digdly,same spd both dlys, no modulation or filter, plain vanilla). It works great until I use my expression pedal. The only thing I have the expression pedal assigned to change is the wet/dry mix. Once I use it it sounds like my delay levels get mixed up. I'll have a noticeably strong delay signal followed by a very faint delay signal with long repeats. I tried this about 5 times in a row to verify that I wasn't hitting anything while using the expression pedal.
