Home Forums Products Rackmount Eventide/GCX interface bank issue Reply To: Eventide/GCX interface bank issue
#117950
IDeangelis
HI Rygar
from Eclipse manual:
Remote Power In
Power supplied at this jack is sent ?down? the MIDI In port?s pins 6 and 7. Use a suitable MIDI pedal board and connect its ?wall wart? (external power supply) to this jack. Use a "7 pin" MIDI cable between the Out port on the board and the In port on the Eclipse.
Power will be remotely supplied to the MIDI pedal board.
So power is provided within these hardware specs.
The reason why you may not be able to recall presets in the 1-100 area is that you are using a wrond MIDI Map. provided you have presets stored in that area, you need to use MIDI Map# 2. Check this out under SETUP > MAPS.
best
