Home Forums Products Stompboxes Switching Time/Modfactor order in pedalboard? Reply To: Switching Time/Modfactor order in pedalboard?
#117999
alwalt
    I am using a 2 channel amp. So, I use a Boss Line Selector to switch between channels. In order to have the TF on both signal paths, I use both A and B inputs/outputs. By doing this, I loose the twin delay option, but I can handle each delay on a patch separatedly. For example, I can have A delay on 0 and B delay on 5. This would fit if have my A channel for rythm and B for lead, just stomp on the LSelector and the delay automatically goes on or off depending on which channel I use. You can mix two delay times on a patch also, having longer delays on one channel. Lots of uses this way, but requieres time to get it organized…
