Home › Forums › Products › Vsig and Preset Development › midi remote help › Reply To: midi remote help
November 24, 2008 at 10:30 pm
#118047
the problem I'm having refers to the midi capture function that allows you to assign a midi controller to a button. (Holding select on a parameter button>then midi remote window appears) I then enter a full controller value to set the remote but when i click "done" i get a error with a loud constant squeek noise. This only happens after editing a preset in vsigfile otherwise it works fine. I guess what im trying to figure out is what im doing wrong while editing. Is it something to do with the function under tools called convert N_EXTCON to remoter? Im lost..
