Home › Forums › Products › Stompboxes › Aux Switch Bank Mode › Reply To: Aux Switch Bank Mode
December 3, 2008 at 11:26 pm
#118080
Hi ashdash,
There are choices in the AUX Switch assignment menu called FS1, FS2, and FS3. When you assign an aux switch to any of these, then that aux switch will do what the corresponding onboard footswitch would do in the opposite performance mode. This is so you get both modes at once.
For example let's say you assign RING to FS2. In Bank Mode, your "ring" aux switch would control Repeat and in Play Mode your "ring" aux switch would select Preset 2 of the current bank. It automatically changes function based on what mode you are in.Cool, right?
-Alan
