Home › Forums › Products › Stompboxes › modfactor 2 questions › Reply To: modfactor 2 questions
#118093
I absolutely second the request for a way to control the volume separately for the effects and even the modes, as the level varies widely among them. For instance, the Liquid Chorus will give you a volume drop whenever you select it – even with Wet at 100 % – whereas the rotary, which otherwise sounds wonderful, gives you that huge jump when you step on it, rendering it nearly useless.
