Home › Forums › Products › Stompboxes › Problem with programming the Expression pedal on TF › Reply To: Problem with programming the Expression pedal on TF
February 6, 2009 at 4:17 pm
#118253
The TF "auto-calibrates" for the pedal, either on powerup, or whenever the pedal is plugged in.
This means that you should power cycle or unplug/replug after making changes to the pedal, and explains what you saw.
