Home Forums Products Rackmount C_IMPULSE Question (H8000 v. 5.3) Reply To: C_IMPULSE Question (H8000 v. 5.3)
#118317
     Control signals are not really suitable for true real-time use, as they can speed up and slow down and even go away for fractions of a second when the machine is busy. This may be what you are seeing, although reliable operation at 8Hz should be achievable.
     Either way, if you are using a signal to directly modulate audio, as in this case, you may prefer to use an actual audio module, such as LFO.
