Home › Forums › Products › Stompboxes › Expression pedal question(s) › Reply To: Expression pedal question(s)
March 4, 2009 at 5:51 pm
#118354
You can use a pedal between about 10K and 25K.
It should be connected between tip (pot center connection) and sleeve. Any necessary power is supplied by the unit.
Trial and error will be safe – it won't break easily unless you connect high voltages to it (DON'T).
