Home Forums Products Stompboxes where to put the pitchfactor? Reply To: where to put the pitchfactor?
#118419
achaput
    Hi Kon,
    PitchFactor will work both in front of the amp and in the effects loop. These two choices have different sounds. In front of the amp is a dirtier sound and might be a good choice for heavy sounds like factory Presets 30:1 through 31:2.
    In the loop is the cleanest way to go. You could try experimenting changing the order of PitchFactor, TimeFactor, and ModFactor in the loop for sound variations.
    Personally I would start with PitchFactor first in the loop, then TimeFactor, then ModFactor and see how you like that.
    That's a killer rig you'll have there!!
    Alan
