Home Forums Products Stompboxes tap tempo in bank mode Reply To: tap tempo in bank mode
#118495
wedelich
    Hi Superfly,
    If you use a 3 switch box with a TRS (tip ring sleeve) connector you can assign one of those swiches to tap. In fact, the default mode for the external switch, when the unit is in bank mode, should mirror the play mode functions.
