Home › Forums › Products › Stompboxes › Problems with settings in play mode › Reply To: Problems with settings in play mode
#118777
If you make adjustments to an effect and you don't store it as a preset, when you switch to a different fx all previous knobs settings are lost. When you go back to the previous fx factory default settings are loaded instead. Save your tweaks.
I
