Reply To: Problems Updating PitchFactor OS
Home Forums Products Stompboxes Problems Updating PitchFactor OS Reply To: Problems Updating PitchFactor OS
#118778
jcshirke
Problem solved. Maybe this info. will help someone else:
If you own an original PF, apparently you have to put the unit into update mode manually before doing any updates. Hold down the middle switch while powering the unit on. Then perform the OS update as usual.
Jeff
