Home Forums Products Stompboxes can aux switches be assigned different functions for bank and play mode? Reply To: can aux switches be assigned different functions for bank and play mode?
#118787
here was my follow-up question, so they can go in the same thread:
after further reading, if i understand correctly, aux switches can
be assigned to control knob functions, and potentially i could assign
multiple knobs to the same switch, then assign max and min values for
these knobs– flex is a separate feature. to get what i'm going for i
probably just need to make several different knob assignments on the
different aux switches.
so my additional question now is:
will the knob assignments i choose be the same for every preset i
create? or is it possible to have a different knob parameter change
assigned to and controlled by the footswitches for each preset (this is
what i hope.)
hopefully they aren't locked in for every preset– it would be
frustrating if i programmed just the right change in delay time to a
footswitch for one preset, but if that change was permanently assigned
to the footswitch, so when i changed patches the same knob adjustment
values created a totally useless sound.
