Home › Forums › Products › Stompboxes › Midi switching for all 3 boxes › Reply To: Midi switching for all 3 boxes
September 14, 2009 at 8:24 pm
#119031
Hi Konstantine,
Did you know you can use one Factor Pedal to control all three? Just get two MIDI cables and connect the pedals this way:
[MASTER] MIDI OUT/THRU (set to OUT)
>[SLAVE1] MIDI IN
[SLAVE1] MIDI OUT/THRU (set to THRU)
>[SLAVE2] MIDI IN
In the MIDI Menu of the pedal you want to be the [MASTER], set PGM XMT to ON.
Now when you change presets on the MASTER pedal, it will also change presets on the other two pedals.
