Home › Forums › Products › Rackmount › Need Chipmunk Effect › Reply To: Need Chipmunk Effect
September 15, 2009 at 7:17 am
#119033
Hi Tee
you can try any pitch shifting preset, using a single voice Many offer from 2 to 4 voices pitch shifting). Try an octave higher (+1200 cents) or even more for chipmunks mayhem.
I would probably start using Multishift 2 (#164). IF your voice signal/track is a stereo one, then use St.Shifter (#162) as it will preserve the input stereo image.
These 2 presets are the clean algorithm you can start with. Set the LOWNOTE to the lowest note in the signal. Set it on C2 if it's dialogue.
best
I
