Home Forums Products Rackmount H8000FW problem: DSP code 2001 Reply To: H8000FW problem: DSP code 2001
#119186
Thanks for the info! I've got more details about the error:
1. Seems like it's more likely to occur during a "cold" boot (e.g. when the device has not been powered for some time) – a fast off/on cycle doesn't reproduce it.
2. After I press continue, the initialization goes on, but then I get another error:
Cannot boot DSP #0. Error 2006 … contact Service Department
3. If I ignore this and press continue again, the device seems to try booting without the failed DSP, and then displays messages like "Something went wrong" (while trying to load a program into the failed DSP), "suggest power down", and, the most informative one – "host timeout".
Did this additional information make things more clear? Maybe now you could tell something more specific about this error. By the way, I have some experience of successfully repairing complex electronic devices, so I could probably perform some kind of other tests if requested, to further investigate the root of this issue without the need of sending the unit overseas yet.
