Home Forums Products Stompboxes TF Volume drop Reply To: TF Volume drop
#119270
    What bypass mode are you using ?
    If you are using the default setting (RELAY), the TF is in effect out of circuit during (true) bypass, so the problem would be elsewhere.
    If you are using another mode, Mr. Caveman's suggestion will be of service.
