Home › Forums › Products › Stompboxes › Timefactor stuck in bypass › Reply To: Timefactor stuck in bypass
#119279
Hey Joey,
The switches themselves actually work OK, which is wierd
I can verify that even the active/bypass switch is working because if i put the box into looper mode and i press the active/bypass leftmost switch (record in loop mode) it does begin to record. But nothing does get recorded
Its like the signal never passes through the actual delay block and the box is acting like a bypass brick
