Home Forums Products Stompboxes TimeFactor: Killdry kills dry? Reply To: TimeFactor: Killdry kills dry?
#119313
    The purpose of killdry is to uh, kill the dry signal. It does this in DSP bypass as well as when not bypassed. It's purpose is for use with a parallel effects loop where the dry signal is always present.
    If for some reason you need to use killdry only when active, you could set the bypass type to relay, when killdry will have no effect.
