Home Forums Products Stompboxes midi Sync’ing Timefactor to Pitchfactor Reply To: midi Sync’ing Timefactor to Pitchfactor
#119338
pauliusmm
Thanks for reply,
I had these settings except my master midi output was set to THRU, now i changed it to XMT, but that didn't solve the problem.
when i tap the tempo on master device (Timefactor) – slave (Pitchfactor) tries to match the bpm and sometimes it gets the tempo not right. For example if i tap 100 BPM on master, slave reads it as 99 BPM.
But even if it gets the tempo right it does not flash in sync , maybe it has something to do with midi start messages??
I am trying  to use harpegiator on Pitchfactor and add some delay from timefactor so any small sync errors sounds awful
Also should i set TEMPO ON on both devices?
also should i turn TEMPO ON on both devices ?
