Home › Forums › Products › Stompboxes › Timefactor Mix Level in a Parallel FX Loop › Reply To: Timefactor Mix Level in a Parallel FX Loop
#119341
Sure I have considered this, but I did like the tone of a blended Timefactor. The question im really after is If I use only the Timefactor in the loop of the gigrig wetbox (With wetbox blend set to 50:50) and the Kill dry setting ON on the timefactor, will my signal output from the wetbox be reduced if I use a Timefactor output less than 50?
If this is the case then I could only get away with blending the Timefactor with the Killdry Setting Off as I want to change delay level based on timefactor presets without signal loss.
