Home Forums Products Rackmount 2nd switch doesn’t work on either H8000fw pedal input. Reply To: 2nd switch doesn’t work on either H8000fw pedal input.
#119376
    It sounds like you are plugging switches into the pedal inputs and using "pedal" as a control source – this would give you the results you described (only the switch connected to the tip would have an effect – that's how pedals work).
    If this is the case, the solution is simple – set the control source to "tip" or "ring" as appropriate.
