Reply To: VoodooLab Ground Control and TF RCV CTL Problem
Home Forums Products Stompboxes VoodooLab Ground Control and TF RCV CTL Problem Reply To: VoodooLab Ground Control and TF RCV CTL Problem
#119406
Assuming by ON and OFF you mean BYPASS..
The latest TF/MF/PF software has a CC option called ACT (ACTive) which is the opposite of BYPASS – this may be what you need.
