Home › Forums › Products › Stompboxes › Using CV to control the Time Factor or Eclipse? › Reply To: Using CV to control the Time Factor or Eclipse?
#119460
    The Eclipse and 'Factor switch and pedal inputs are protected against reasonable over-voltages. We don't specify a maximum, but 5-15V should be OK.
    Note that the 100% voltage point on the Factor pedal input is about 3.3V – it will clip above this. The Eclipse 100% point is about 5V.
