Home Forums Products Stompboxes Using CV to control the Time Factor or Eclipse? Reply To: Using CV to control the Time Factor or Eclipse?
#119461
haven
    Thanks for the answer – Looks like a I have some experimenting to do!
    One more question, should the voltage be at the tip or the ring of the cable? I want to be able to put the Expression inputs into my patchbay so I can patch either expression pedals or CV.
    Should I make a special cable or adapter to patch the TS CV cable into the TRS Expression input?
