Reply To: Pitchfactor’s Tempo Readout Values
Home Forums Products Stompboxes Pitchfactor’s Tempo Readout Values Reply To: Pitchfactor’s Tempo Readout Values
#119478
The issue referred to was not an accuracy problem, it was that the unit allowed you to select a value greater than the maximum.
75 BPM is 1.25 beats per second, which corresponds to 1000/1.25 = 800 mS, so what you see is probably correct.
