Home Forums Products Stompboxes Why does selecting MIDI THRU disable all MIDI Transmit functions in Factor stompboxes? Reply To: Why does selecting MIDI THRU disable all MIDI Transmit functions in Factor stompboxes?
#119711
    MIDI Thru simply connects the MIDI in to the MIDI out – this is a pretty standard implementation.
    It would, as you mention, be nice if the MIDI THRU function could be combined with a MIDI Merge function, but this is not possible at the present time.
    MIDI Merge boxes are available at low cost, which will allow you to do what you want.
