Home › Forums › Products › Stompboxes › Midi Noob problem met Timefactor or? › Reply To: Midi Noob problem met Timefactor or?
January 6, 2010 at 8:05 pm
#119735
TimeFactor can be put into Bypass via a MIDI Continuous Controller message. This can be set in the System Mode's MIDI/RCV CTL menu.
You pick a MIDI CC number that you want to use and set your G-Labs to transmit a MIDI CC message on that same controller number in order to Bypass the TimeFactor.
