Home › Forums › Products › Stompboxes › midi talk › Reply To: midi talk
January 25, 2010 at 7:26 pm
#119852
Hi jrbs,
In PitchFactor's System Mode under MIDI, make sure CLK IN is set to ON and CLK OUT is set to OFF.
You also have to make sure that PitchFactor's RVC CH (Receive Channel) is either OMNI or matches that MIDI Channel of the Boss pedal.
Make sure PitchFactor is in Tempo Mode (Press the Encoder Button in PLAY or BANK Mode to toggle Tempo.)
Doing these things will prepare PitchFactor for receiving MIDI Clock from the Boss.
You may have to check the Boss User Guide to determine how to set it up for transmitting MIDI Clock.
