Home Forums Products Stompboxes System Mode on Mod Factor Reply To: System Mode on Mod Factor
#119869
    This is normal behavior – it remembers where you last were in the the system menu.
    Press the center switch to go towards the top level, turn the encoder to select other options.
    So, if you see "BYP TYP", hit the center switch once to get to "BYPASS", and then turn the encoder to get "AUX SW", "MIDI" etc.
