Home Forums Products Stompboxes Anybody else getting a volume boost with the new software? Reply To: Anybody else getting a volume boost with the new software?
#119882
wedelich
Hi dissever,
Which pedal are you using, and on which algorithms is the volume boost noticeable (as in, just in Tape Delay, or across the board) ?  Make sure your input/output level switches are still the same as you used before the update.  Also, are you referring to the DSP+FX bypass setting in system mode?
