Home Forums Products Stompboxes Timefactor with boss FS-5U….tap tempo issue Reply To: Timefactor with boss FS-5U….tap tempo issue
#119939
    It is possible to assign multiple things to a given aux switch or MIDI controller. This gives versatility, but can cause confusion, as now.
    Look through all the AUX switch options, and you will probably find more than one thing assigned  to your switch. The solution will be apparent.
