Home Forums Products Stompboxes Midi TF/MF Reply To: Midi TF/MF
#119967
achaput
    Hi Daniele,
    The way to do what you are asking with the footswitches is to get a 3-button aux switch and a y-cable so you can connect it to both Factor pedals at once. You can program the aux switch to do whatever you want.
    You should be able to use a y-cable with an expression pedal also if you want to control both Factor pedals.
