Home Forums Products Stompboxes Sync Time Factor BPM with MIDI Murf? Reply To: Sync Time Factor BPM with MIDI Murf?
#119986
It looks like the MIDI Murf has a MIDI IN port only, and can follow MIDI Clock. That means if you turn on TimeFactor's MIDI Clock Out  (CLK OUT in the MIDI Menu under System Mode) and connect TimeFactor's MIDI OUT to the Murf's MIDI IN, the two devices should be in sync.
