Home Forums Products Stompboxes Pedal Board for Eventide Stopboxes Reply To: Pedal Board for Eventide Stopboxes
#119988
tomasgunn
    I recently switched to the furman as well.  I really like it and I'm using the adapters that come with the Eventide stomp boxes (well, for 2 out of 3 pedals).  However, there's a problem with those adapters that I didn't anticipate.  Even though the spacing between the AC inputs on the pedal board is generous and designed with wall warts in mind.  It is still not generous enough for the Eventide adapters.  You cannot have two side by side (or in my case, three).
    It would be real nice to have a single supply with for all three pedals with little footprint and isolated outs for each pedal.  Ideally one that does not take away actual pedalboard space.  I don't mind the fact that it's a wall wart.
