Home › Forums › Products › Rackmount › Eclipse and H8000 › Reply To: Eclipse and H8000
February 25, 2010 at 5:06 pm
#120047
Yes you can…IF you know how the Eclipse algorithms are made.
Series,
parallel is not a problem.
Xfade doesn't make sense as you have
two DSPs so you can:
-use the other DSP to switch to another
preset
-build algorithms in a way that you can internally switch
between parts of them (from a verb to a chorus, for instance).
best
I
