Home › Forums › Products › Stompboxes › Issues with setting up my board – A/B switching sets expression parameters to zero › Reply To: Issues with setting up my board – A/B switching sets expression parameters to zero
March 2, 2010 at 5:04 pm
#120072
Well, that makes sense. An expression pedal is basically a volume pedal, and when it's in heel position, no signal is going through. This is what the Factor reads. When you hit the A/B switch, you are effectively doing the same thing as setting the pedal to heel, in an electrical sense. I don't see much of a way around this.
