Home Forums Products Stompboxes [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active. Reply To: [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active.
#120090
I have a problem with the new bypass functions. I control the TF with a Musicom Lab EFX MKII, and I wanted to control the TF's bypass via PCs. But it doesn't work properly.
EX :
1) I send a PC with value 1 -> the TF is active on preset 1:1
2) I send a PC with value 2 -> the TF is active on preset 1:2
3) I send a PC with value 125 (preset with no delay) -> it bypasses the TF
4) I send another PC with value 125 (other preset with no delay) -> it activates the TF!
In fact, PC 125 which is supposed to be a bypass function is acting like a togle between bypass and active…
What I wanted to do is to send a PC 125 on evrey preset where I don't need delay to have the TF bypassed…
