Home › Forums › Products › Vsig and Preset Development › TextTrigger string display problem › Reply To: TextTrigger string display problem
#120131
sean.e
    I wrote to support noting that this problem is not addressed in OS5.5B and added this information:
    The TextTrigger has 4 values:
    default off
    option 1 ON
    option 2 ON
    option 3 ON
    The H8000 displays these values:
    default ofoption
    option 1 Ooption
    option 2 Ooption
    option 3 ON
    nick:
    i) Vsig
    correctly displays a maximum length of 10 chars for this field, but then
    allows you to enter 11.
    ii) The H8000 should allow a 10-char value with no terminator, but seems
    to demand a terminator, which is why it runs into the next field.
    So far as I can tell, there is no
    indication in VSig that the max length is 10 characters.  VSig displays
    the text properly in the specifier display  The text type Max column is blank.
    The Min column has length.  It does show that the maximum number of
    strings is 10 (nstrings).
