Home Forums Products Stompboxes TimeFactor: Fine Tuning Delay Times Reply To: TimeFactor: Fine Tuning Delay Times
#120142
EdDrake
    Not sure if this is what you're talking about.
    From page 24 of the TF manual:
    Adjusting Tempo & Tweaking Delays
    The Encoder can be used to set or tweak the Tempo value in BPM if Tempo is ON. To use the
    Encoder, first press the Tap Footswitch (you must be in Play Mode) so that the Billboard
    displays the Tempo value in BPM. Whenever the Tap value is displayed, the Encoder can be
    turned to adjust the Tempo. While adjusting, the Billboard displays the updated Tempo and
    the parameter Control Knobs are disabled.
    With Tempo OFF, the Encoder can be used to tweak delay time. To use the Encoder, first turn
    the Control Knob corresponding to the delay that you want to tweak; either Dly Time A or Dly
    Time B. Next, press the Tap Footswitch (TimeFactor must be in Play Mode) so that the
    Billboard displays the Delay Time value. Now turn the Encoder to adjust Delay Time. While
    adjusting, the Billboard displays the updated Delay Time and the parameter Control Knobs are
    disabled.
