Reply To: Pitchfactor Expression Pedal Values Jump
Home Forums Products Stompboxes Pitchfactor Expression Pedal Values Jump Reply To: Pitchfactor Expression Pedal Values Jump
#120189
Maybe a bad contact at the jack – try pulling it in and out 10 times, with a bit of switch cleaner on the plug if you can find some.
If this doesn't fix it, it probably needs to be looked at.
