Home Forums Products Stompboxes Stereo Pedalboard Reply To: Stereo Pedalboard
#120212
DGillespie
    You can go stereo in and mono out, however if there is nothing on the right (channel 2) stereo input you may not get the desired effect.  For instance in TF if you plug both inputs in and there is nothing on the channel 2 input you will not be feeding the B delay, and you will only hear one delay output.
    Does that answer your question?
