Home Forums Products Rackmount Orville Dry/Wet Reply To: Orville Dry/Wet
#120220
Hi dood
the dry/wet ratio can only be set for the system, not for the single preset.
A few presets may have separated dry and wet levels. Others may be modded using Vsigfile editor.
Or you could route dry and wet signals thru Orville oitputs, using the routing configuration page.
Then using MIDI CC messages you could remote levels settings.
all the best
Italo
