Home › Forums › Products › Stompboxes › Control MF with TF › Reply To: Control MF with TF
March 31, 2010 at 11:01 pm
#120237
Some User Manual reading will be required, but you could set it up so that loading a preset on one unit loads an appropriate preset on the other. It will be a bit of a fiddle unless they have the same numbers.
Look for the explanations of [TX MAP] and [RX MAP]
