Home Forums Products Stompboxes TimeFactor and MIDI Clock Reply To: TimeFactor and MIDI Clock
#120252
achaput
    In the MIDI menu of System mode, set CLK OUT to ON. Then the TimeFactor will transmit MIDI clock of the tempo saved in any preset.
    You can connect an aux switch to TimeFactor and have that transmit MIDI CC messages. If the device you're transmitting to can interpret those messages as tempo, then you should be able to tap MIDI tempo on the aux switch.
